quota for ext4 vs xfs (grpquota or pquota ?)
trover
i done enable quotas in CentOS 7 (xfs) but i got doubt after reading this guide:
https://help.directadmin.com/item.php?id=557
As well, we replace the grpquota with pquota (project quotas), which will allow DA to setup directoy quotas, for things like enforcement of per-domain disk quotas.
in CentOS 6 (ext4) i using (usrquota,grpquota) in /etc/fstab like this:
/home         ext4          defaults,usrquota,grpquota
also i done same in CentOS 7 (xfs) and i think its fine:
# /usr/sbin/repquota /home
*** Report for user quotas on device /dev/mapper/centos-home
Block grace time: 7days; Inode grace time: 7days
                        Block limits                File limits
User            used    soft    hard  grace    used  soft  hard  grace
root      --     100       0       0             19     0     0
admin     --     336       0       0             38     0     0
but im not sure after reading this part:
so which way is the best? and is this fine to use pquota for ext4 and xfs?
/home          xfs         defaults,usrquota,grpquota
/home          xfs         defaults,usrquota,pquota
/home          xfs         defaults,uquota,prjquota
Have the same question. Must say, I've found these instructions don't cover a lot of scenarios. My grep output says:
/dev/mapper/centos-home on /home type xfs (rw,relatime,attr2,inode64,usrquota,grpquota)
There is nothing about prjquota here
