I have installed DirectAdmin on a xen vps at Linode.com, everything was working perfect out of the box, until after I finished migration from another box, I discovered that quota did not work on my vps at Linode. It is running CentOS 6.2 64bit.
First the problem was that my /etc/fstab did not contain userquota,groupquota , so I added those and rebooted. However it did not help.
When I run the command:
I get this:
However after many hours search I found that /dev/root was missing in my server, so I added symlink by running:
Then I run:
And now quota is working.
However the problem is that after reboot /dev/root is missing again, so I have to add it again after each reboot.
How can I add /dev/root so that it is not missing after reboot? Please help me suggest at command to add it differently?
Also I have been asking for help in Linode forum (I am user ditto), here is the thread: http://forum.linode.com/viewtopic.php?t=8294
The last reply a user say that /dev/root seems to be deprecated?
I would be thankful for any help!
/sbin/quotaoff -a; /sbin/quotacheck -avugm; /sbin/quotaon -a;
I get this:
quotacheck: Cannot find filesystem to check or filesystem not mounted with quota option.
ln -s /dev/xvda /dev/root
Then I run:
From the looks of things, /dev/root seems to be deprecated (based on 1 and 2). From a quick survey, I have it on my Ubuntu 10.04 workstation and Linode, but not on my Ubuntu 11.10 netbook.
It might be worth checking with the DirectAdmin folks, as it is a commercial product and they've probably run into this sort of stuff before. (I don't believe I'd heard about it prior to this thread.)
Worse comes to worse, /etc/rc.local.
