redirection problem
How did you create the redirection?
Please merge both of your redirection threads into one and delete the one you've decided to not use.
You can delete a thread by entering "Edit" and then there's a delete option at the top.
Thanks.
no 2 fixed... after a few hours
no 1 still occuring, made the redirection in the DA interface.
If you post a screenshot of the problematic redirection maybe we can figure it out.
The httpd configuration format has been tested and used for many years, and I'm sure it's working properly.
In order for me to see whether you're making a mistake in what you're typing, or there's a bug in DA, or something else is going on, then I'd need to see a screenshot.
If you can't do that, then I'd suggest you contact DA tech support if it's your DA license, or otherwise your hosting company for support.
