Redis does not appear to work
sunsunshining
It is enabled in custombuild and I try to use it in a Wordpress site. However, when I try to follow the info here, I see no "Redis" option in Advanced features.
Enable redis for your user by going to user level -> Advanced Features -> Redis. Take note of the Path to redis socket file value.
I also tried these on the shell and I got command not recognized:
systemctl status redis
redis-cli ping
Most likely you are on directadmin legacy license which does not have this function enabled.
It was prepared by a tech and I can see Redis in phpinfo... Not sure if that means something....
When I click on the option to build Redis I get
You cannot install Redis, because you do not have redis=yes set in options.conf file.
I changed that option to yes, it did build, but now I get when I run redis-cli on terminal:
Could not connect to Redis at 127.0.0.1:6379: Connection refused
I opened TCP ports in CSF for 6379, restarted, same output.
see them all: ls -la /home/*/.redis/redis.sock
.. and maybe in joomla: /domains/domain.xy/public_html/administrator/components/com_config/forms/application.xml
lines 140, 895 --> set min="1" --> min="0"
