Redis Installation Help
itcms
Athens
Because confused
I have installed REDIS following this :
dnf install redis
systemctl enable --now redis.service
systemctl start redis.service
chown redis:redis /etc/redis.conf
In custom-build
./build set redis yes
./build redis
I missed something ?
Why I dont see Redis as service under system-info ?
what type of your license ?
Redis need Propack
Retail: Lite or Standard
Lifetime License: Need to buy support update
Internal: No information aboit this, maybe there have option to include propack with increase price
dnf install redis
You not need to install redis by yourself, Custombuild will handle for you
Please remove with
yum remove redis
License is Lite
If I have understand well without propack installs only phpredis extension and compile php , redis need installation by admin
I want to clarify that because confusing and its not clear else why to have redis option ?
As I checked doesnt install redis server, maybe I am wrong
./build redis
Custombuild can build anything for you even you don't have propack
Propack will be GUI Management eg. enable / disable redis per user
but building redis with custombuild will be useless, because it use unix socket file
That I observed in another installation :
Enabling redis in systemd...
Enabling redis-rspamd in systemd...
Created symlink from /etc/systemd/system/multi-user.target.wants/redis-rspamd.service to /etc/systemd/system/redis-rspamd.service.
--2021-10-04 16:40:22-- https://files1.directadmin.com/services/custombuild/redis.logrotate
Resolving files1.directadmin.com (files1.directadmin.com)... 104.128.54.74
Connecting to files1.directadmin.com (files1.directadmin.com)|104.128.54.74|:443... connected.
Length: 127
Saving to: '/etc/logrotate.d/redis'
Install redis-rspamd not normal redis if you have enabled rspam
Conclude , if I am wrong please correct :
With option :
./build redis
Then :
If rspamd is installed : Installed redis-rspamd
If not rspamd : Then no redis instance installed
In both of above php extension for redis supports installed and compiled
The redis-rspamd is not compatible with "classic" installation, not recognized from redis apps , needs extra dnf install redis
I remember, There have thread talking about like this about rspamd
This can help you ?
Also this doc says
Thanks a lot , I didnt noticed this post
Its obviously need pro pack enabled to have redis server.
Without propack you handle it by own , BUT if you have rspamd then you will face conflicts , you will have up two redis instances
