I've reniewed my SSL cert, all ok, but when clicking on the ssl cert, it gives a problem
Click link for pic...any idea?
http://sensualfeeling.nl/cert.JPG
Secure Connection Failed
sensualfeeling.nl uses an invalid security certificate.
The certificate is not trusted because it is self signed.
The certificate is only valid for www.sensualfeeling.nl
(Error code: sec_error_ca_cert_invalid)
* This could be a problem with the server's configuration, or it could be someone trying to impersonate the server.
* If you have connected to this server successfully in the past, the error may be temporary, and you can try again later.
Or you can add an exception…
