Restoring, need help
Bullcat
Netherlands / Haarlem
After a server crash , i have setup a fresh install of DA , i make every night a backup of /usr/local/directadmin/data , var/lib/mysql and /home
That is all i have, i have already see that under directadmin de owner is majordomo , so i will make directadmin the owner, but in /home i see only numbers as owner.
Is there someone who can help me fixing this all, ore can explain what i have to do to setup everything working fine ?
Regards
Hans
I'am using backupPC as program for the backups.
You really didn't back up enough to make this easy. i think you'll have to set up each user/domain manually, and then restore the contents.
