powerdomein
- Dec 28, 2005
I habe just set my R DNS.
Name Type Value Select
200.34.12.85.in-addr.arpa. NS ns1.bulduk.nl.
201.34.12.85.in-addr.arpa. NS ns2.bulduk.nl.
200.34.12.85.in-addr.arpa. PTR bulduk.nl.
When i check with
http://www.dnsreport.com/tools/dnsreport.ch?domain=bulduk.nl
i get error message:
ERROR: The IP of one or more of your mail server(s) have no reverse DNS (PTR) entries/* (if you see "Timeout" below, it may mean that your DNS servers did not respond fast enough)*/. RFC1912 2.1 says you should have a reverse DNS for all your mail servers. It is strongly urged that you have them, as many mailservers will not accept mail from mailservers with no reverse DNS entry. You can double-check using the 'Reverse DNS Lookup' tool at the DNSstuff site if you recently changed your reverse DNS entry (it contacts your servers in real time; the reverse DNS lookups in the DNS report use our local caching DNS server). The problem MX records are:
200.34.12.85.in-addr.arpa [No reverse DNS entry (rcode: 3 ancount: 0) (check it)]
Can Some one HELP ME? What can be WRONG??
When i check with
