pereirar2z
- Feb 23, 2024
Hi all, Thank you for any help provided. It will be highly appreciated.
I'm running dovecot-2.3.21-1.x86_64 + dovecot-pigeonhole-2.3.21-1.x86_64 + roundcube 1.6.6 on my redhat server. Mailserver is working as expected with the exception of the filters. I've installed and configure everything that i'm aware of but unfortunatelly its not working. I already recreate all my configuration from scracth but no major improvements so far.
At the moment my suspicious goes to the following:
Dovecot is not loading this module: /usr/lib/dovecot/modules/lib90_sieve_plugin.so.
But i have no idea what can I do more. Can you please help me?
I've paste here the output of doveconf -n:
On Round Cube I can set the filters that i need but as soon as i click save nothing happens.
Can you please point me into another direction?
Regards, Pereira
# 2.3.21 (47349e2482): /etc/dovecot/dovecot.conf
# Pigeonhole version 0.5.21 (f6cd4b8e)
# OS: Linux 4.18.0-513.11.1.el8_9.x86_64 x86_64 Red Hat Enterprise Linux release 8.9 (Ootpa) xfs
# Hostname: xxxxxx.xxxxx
auth_debug = yes
auth_verbose = yes
disable_plaintext_auth = no
first_valid_uid = 1000
listen = *
log_path = /var/log/dovecot.log
mail_debug = yes
mail_location = maildir:/home/vmail/%d/%n/Maildir
mail_plugins = acl mail_log notify
mail_privileged_group = mail
managesieve_notify_capability = mailto
managesieve_sieve_capability = fileinto reject envelope encoded-character vacation subaddress comparator-i;ascii-numeric relational regex imap4flags copy include variables body enotify environment mailbox date index ihave duplicate mime foreverypart extracttext
mbox_write_locks = fcntl
namespace inbox {
inbox = yes
location =
mailbox Drafts {
special_use = \Drafts
mailbox Junk {
special_use = \Junk
mailbox Sent {
special_use = \Sent
mailbox "Sent Messages" {
special_use = \Sent
mailbox Trash {
special_use = \Trash
prefix =
passdb {
args = /etc/dovecot/dovecot-sql.conf.ext
driver = sql
plugin {
sieve = ~/.dovecot.sieve
sieve_default = /var/lib/dovecot/sieve/default.sieve
sieve_dir = ~/sieve
sieve_global = /var/lib/dovecot/sieve/global/
protocols = imap pop3 sieve lmtp
service auth-worker {
user = vmail
service auth {
unix_listener /var/spool/postfix/private/auth {
group = postfix
mode = 0666
user = postfix
unix_listener auth-userdb {
mode = 0600
user = vmail
user = dovecot
service lmtp {
unix_listener /var/spool/postfix/private/dovecot-lmtp {
group = postfix
mode = 0600
user = postfix
service managesieve-login {
inet_listener sieve {
port = 4190
process_min_avail = 4
service_count = 1
vsz_limit = 64 M
service stats {
unix_listener stats-reader {
group = wheel
mode = 0666
user = dovecot
unix_listener stats-writer {
group = wheel
mode = 0666
user = dovecot
ssl_cert = </etc/pki/dovecot/certs/dovecot.pem
ssl_key = # hidden, use -P to show it
userdb {
args = uid=vmail gid=vmail home=/home/vmail/%d/%n/Maildir
driver = static
verbose_ssl = yes
protocol lmtp {
mail_plugins = acl mail_log notify quota sieve
protocol sieve {
info_log_path = /var/log/dovecot-sieve.log
log_debug = category=sieve
managesieve_implementation_string = Dovecot Pigeonhole
managesieve_logout_format = bytes=%i/%o
managesieve_max_compile_errors = 5
managesieve_max_line_length = 64 k
Regards, Pereira
