Sendmail problem after upgrade
GITK Services
Lancashire, UK
I upgraded FreeBSD to 4.10-RELEASE, and now all local mail scripts (e.g. website feedback forms etc) that point to a local mail account have a bounce error similar to the following going to the root user:
The original message was received at Thu, 15 Jul 2004 09:33:02 -0700 (PDT)
from localhost.hyperinfinity.net [127.0.0.1]
----- The following addresses had permanent fatal errors -----
<[email protected]>
(reason: 553 5.3.5 system config error)
----- Transcript of session follows -----
553 5.3.5 mail.gitk.com. config error: mail loops back to me (MX problem?)
554 5.3.5 Local configuration error
Reporting-MTA: dns; server1.hyperinfinity.com
Received-From-MTA: DNS; localhost.hyperinfinity.net
Arrival-Date: Thu, 15 Jul 2004 09:33:02 -0700 (PDT)
Final-Recipient: RFC822; [email protected]
Action: failed
Status: 5.3.5
Diagnostic-Code: SMTP; 553 5.3.5 system config error
Last-Attempt-Date: Thu, 15 Jul 2004 09:33:02 -0700 (PDT)
Subject:
Test Subject
[email protected]
Date:
To:
[email protected]
Automated web query
This is a test enquiry. Something's not quite right here.
I'm assuming it's something to do with the virtual host table or something being overwritten when the upgrade was performed, but can anyone advise how to rebuild / fix the issue? I do have a copy of the /etc files, pre-upgrade, as a backup.
Thanks in advance.
Richard.
Found the issue. After doing a pair of telnet's to the SMTP port, one externally and one internally, and looking at the banners, it showed running Sendmail locally, but Exim externally, so it was throwing a fit. I altered the mailer.conf file to point at exim and not sendmail, and did a killall sendmail. It's now talking locally to exim, without a problem. I'm not sure if it's going to try to restart sendmail on reboot, but I couldn't find any startup references, so it should be okay. Just for note to any other upgraders!
Rick.
