Shoutcast starting problem.
kanomen
I was using shoutcast on my server but after restarted my server there is an error occured.
/libexec/ld-elf.so.1: Shared object "libpthread.so.1" not found, required by "sc_serv"
What you offer me to do ?
Thanks.
Kind Regards.
You have got to install the libpthread, or add the path, where the libpthread.1 is installed in your the LD_LIBRARY_PATH or make a link from where the location of th e libs to /usr/lib.
Try locate libpthread.so.1
and post outcome here
Maybe u could post the OS here and the specific error's
server# locate libpthread.so.1
/usr/lib/libpthread.so
/usr/lib/libpthread.so.2
server# locate libpthread.so.2
server# locate libpthread.so.0
/usr/lib/libpthread.a
/usr/lib/libpthread_p.a
server#
I searched google and found this help try it and maybe it will work.
fix it by doing this:
su (root)
cd /usr/ports/misc/compat5x
make clean install
rehash
Now fireup shoutcast (5x binary) should work for ya
I do like this :) it's funny but solved totally.
su (root)
make deinstall
make clean install
rehash
I have tried this until Im blue in the face and I get a error. Im new to servers so I may not be trying it exactly like im supposed to.
I have tried this, :
su root
make deinstall
make clean install
rehash
When i Try this is what I get:
$ su (root)
Syntax error: word unexpected (expecting ")")
$ cd /usr/ports/misc/compat5x
$ make clean install
===> Cleaning for localedata-5.4
===> Cleaning for compat5x-i386-5.4.0.8_7
===> Vulnerability check disabled, database not found
mkdir: /usr/ports/distfiles: Permission denied
*** Error code 1
Stop in /usr/ports/misc/compat5x.
$ rehash
Do I need to edit that for my machine? When I try it, it tells me that hash cant be found and that i have insufficient permission to make file. I rent the server and have full access. So my guess is im trying something wrong.
I installed the shoutcast then used the ./sc_serv and I got the smae error that the author of this post got as well. EXCEPT I never got mine started. :-( Please help a newbie out.
su (root)
make deinstall
make clean install
rehash
U dont type su (root) u type su root [enter] then typ in password for root and then try the other lines
Ok I tried that and i typed in su admin (root wouldnt work) and something happened but not what should have I dont think. Here is what I got and you can tell where i typed in each line from the above fix.
$ su admin
Password:
$ make deinstall
===> Switching to root credentials for 'deinstall' target
su: Sorry
*** Error code 1
*** Error code 1
$ rehash
rehash: not found
Im so stuck now. :-( the install went smooth all the way to this point.
I forgot to mention that I am using freebsd 6 with DA obviously.
If u need any help contact me on ICQ,msn (email same as emailadress ) or via email my adress is hans (at) tind dot nl
Ok thx. Much appreciated. I added you to msn. I hope I added the correct email.
Make sure you are installing the program as root user:
su -
make deinstall reinstall clean
Actually, I tried that as well and got the same permission denied error. And the funny part is, its my box. So I dont know why i would have a permission issue. BUT Ill give it a go one more time as admin and see what happens. ;-)
This is what I get if I try logged in as root user
$ make deinstall reinstall clean
su: Sorry
*** Error code 1
I dont understand why it says switching credentials to root if thats what Im logged in as.
U added the right adress (assuming u are Ray )
Ill contact u later on the day ( its now noon here so u should be asleep lol )
If u see me online on msn pm me and ill help u out ( as much as i can )
yep. thats me. ;-) Sry I havent been on msn lately. Ill leave it on incase you sneak on and have a few minutes to spare. Im normally on yahoo, but as I said, Ill go ahead and run msn.
And thx again
