Site help
joseph
my site is the following
x-xphere.co.uk
i type that into my address bar it comes up with a page not found error, also, i did a subdomain for my future forum so the url for this is 'forum.x-xphere.co.uk' then within the forum directory i added a 'root' a 'root directory' and 'admincp' within i put php documents, .txt format and a php instalation (ibproarcade-vbulletin') but cannot install....any help?
Hey,
Network Solutions is not showing "x-xphere.co.uk" as registered... It says it is still available...
That could be your problem...
It's 8:30pm CDT when I checked it...
David
it should be registered as i did get the info in the email that wa sent to me
Just because that was the domain that was in the welcome email sent by DirectAdmin does not mean that your purchased it. ;)
In reality it probably means your hosting account is setup to use that domain, now you must buy it and configure the nameservers to what your hosting provider instructed you to do so.
