Softaculous Problem Folder Permission
El CapitanPH
Hello Good Day
So i setup a test server and i notice when i use softaculous to install magento , Var - media - include folder have 777 permission
Other script is working good like wordpress , joomla , drupal
Btw I'm using Cloudlinux os ,
nginx_apache and php 7,2 version
If you find Softaculous setting wrong permissions to an application folder you installed, then you might need to report it to them. The plugin for DirectAdmin is developed by Softaculous developers, and only they can fix it.
