Spamassassin Woes - Please Help
Brian
I install SA as per http://www.directadmin.com/forum/showthread.php?s=&threadid=1193&highlight=spamassasin
When trying to send a mail via squirrelmail or outlook to another account on the same machine i get returned mail saying....................
An error was detected while processing a file of BSMTP input.
The error message was:
421 Lost incoming connection
The SMTP transaction started in line 0.
The error was detected in line 3.
0 previous messages were successfully processed.
The rest of the batch was abandoned.
Transaction started in line 0
Error detected in line 3
Any ideas????
See you can send mail from a externial mail server to your box.
Check
/var/log/maillog &
/var/log/exim/exim_*
Hmm external mail used to work but when i tried to send a mail from hotmail to account on machine it didn't arrive but i didn't get a message failed email either????
I can send mail out of the machine
Exim Log
==> /var/log/exim/exim_mainlog <==
2004-02-24 09:39:07 1AvZ1t-0004NI-Sq => [email protected] R=lookuphost T=remote_smtp H=mx3.hotmail.com [65.54.167.5]
2004-02-24 09:39:07 1AvZ1t-0004NI-Sq Completed
2004-02-24 09:39:40 1AvZ2S-0004NO-IU <= [email protected] H=(hotmail.com) [64.4.11.69] P=esmtp S=1135 [email protected]
2004-02-24 09:39:40 SMTP connection from mail lost while reading message data (header)
2004-02-24 09:39:40 1AvZ2S-0004NO-IU <[email protected]>: spamcheck transport output: An error was detected while processing a file of BSMTP input.
2004-02-24 09:39:40 1AvZ2S-0004NO-IU ** [email protected] R=spamcheck_director T=spamcheck: Child process of spamcheck transport returned 2 from command: /usr/sbin/exim
2004-02-24 09:39:40 1AvZ2S-0004NV-Rq <= <> R=1AvZ2S-0004NO-IU U=mail P=local S=2417
2004-02-24 09:39:40 1AvZ2S-0004NO-IU Completed
2004-02-24 09:39:42 1AvZ2S-0004NV-Rq => [email protected] R=lookuphost T=remote_smtp H=mx2.hotmail.com [65.54.190.7]
2004-02-24 09:39:42 1AvZ2S-0004NV-Rq Completed
==> /var/log/exim/exim_paniclog <==
2004-02-23 03:01:56 1Av6M0-00026S-Ou User 0 set for local_delivery transport is on the never_users list
2004-02-23 03:01:57 1Av6M0-00026j-VM User 0 set for local_delivery transport is on the never_users list
2004-02-23 03:01:57 1Av6M1-00027F-F3 User 0 set for local_delivery transport is on the never_users list
2004-02-23 03:01:57 1Av6M1-00027I-J7 User 0 set for local_delivery transport is on the never_users list
2004-02-24 00:05:01 1AvQ4K-0003d4-LW User 0 set for local_delivery transport is on the never_users list
2004-02-24 00:05:01 1AvQ4L-0003d8-Ep User 0 set for local_delivery transport is on the never_users list
2004-02-24 03:01:50 1AvSpS-0003u9-Gu User 0 set for local_delivery transport is on the never_users list
2004-02-24 03:01:50 1AvSpS-0003uP-ND User 0 set for local_delivery transport is on the never_users list
2004-02-24 03:01:51 1AvSpT-0003uy-91 User 0 set for local_delivery transport is on the never_users list
2004-02-24 03:01:51 1AvSpT-0003v2-II User 0 set for local_delivery transport is on the never_users list
==> /var/log/exim/exim_rejectlog <==
2004-02-19 02:32:42 SMTP protocol violation: synchronization error (input sent without waiting for greeting): rejected connection from H=[ip address]
2004-02-19 07:35:17 SMTP call from (domain.com) [81.130.105.172] dropped: too many nonmail commands (last was "NOOP")
2004-02-19 12:16:48 H=(winxp) [61.73.48.64] F=<[email protected]> rejected RCPT <[email protected]>: authentication required
2004-02-20 02:18:51 SMTP protocol violation: synchronization error (input sent without waiting for greeting): rejected connection from H=[ip address]
2004-02-21 02:33:49 SMTP protocol violation: synchronization error (input sent without waiting for greeting): rejected connection from H=[ip address]
2004-02-21 05:16:26 H=(194.159.247.46) [219.91.108.96] F=<[email protected]> rejected RCPT <[email protected]>: authentication required
2004-02-21 06:47:35 SMTP protocol violation: synchronization error (input sent without waiting for greeting): rejected connection from H=[216.34.38.66]
2004-02-22 14:33:30 H=(your-ykj3fdh0wj) [220.71.86.94] F=<[email protected]> rejected RCPT <[email protected]>: authentication required
2004-02-23 00:15:58 H=(Post.cz) [12.65.168.112] F=<[email protected]> rejected RCPT <[email protected]>: authentication required
2004-02-24 02:31:40 SMTP protocol violation: synchronization error (next input sent too soon): rejected "RCPT TO:<[email protected]>" H=(niiallisha) [24.15.131.107]
I commented out the spamassassin lines in exim.conf and everything now works as it should (including local delivery)
Any ideas on what could be going wrong?
Tried and get the following
Can't locate HTML/Parser.pm in @INC (@INC contains: ../lib /usr/local/lib/perl5/site_perl/5.8.0 /usr/local/lib/perl5/site_perl/5.8.0/mach /usr/local/lib/perl5/site_perl /usr/local/lib/perl5/5.8.0/BSDPAN /usr/local/lib/perl5/5.8.0/mach /usr/local/lib/perl5/5.8.0 .) at /usr/local/lib/perl5/site_perl/5.8.0/Mail/SpamAssassin/HTML.pm line 7.
BEGIN failed--compilation aborted at /usr/local/lib/perl5/site_perl/5.8.0/Mail/SpamAssassin/HTML.pm line 7.
Compilation failed in require at /usr/local/lib/perl5/site_perl/5.8.0/Mail/SpamAssassin/PerMsgStatus.pm line 44.
BEGIN failed--compilation aborted at /usr/local/lib/perl5/site_perl/5.8.0/Mail/SpamAssassin/PerMsgStatus.pm line 44.
Compilation failed in require at /usr/local/lib/perl5/site_perl/5.8.0/Mail/SpamAssassin.pm line 62.
BEGIN failed--compilation aborted at /usr/local/lib/perl5/site_perl/5.8.0/Mail/SpamAssassin.pm line 62.
Compilation failed in require at /usr/local/bin/spamd line 32.
BEGIN failed--compilation aborted at /usr/local/bin/spamd line 32.
It would seem you're missing the HTML::Parser module.. can be found here:
http://search.cpan.org/CPAN/authors/id/G/GA/GAAS/HTML-Parser-3.35.tar.gz
wget http://search.cpan.org/CPAN/authors/id/G/GA/GAAS/HTML-Parser-3.35.tar.gz
tar xvzf HTML-Parser-3.35.tar.gz
cd HTML-Parser-3.35
perl Makefile.PL
make
make install
That should get you up and going.
OK did that and all installed ok, uncomment the spamd lines from exim.conf again and restarted
did ps aux | grep spamd which returned nothing.
Tried sending a mail from outside account and got
again :(
Did
cryo#spamd &
[1] 58963
cryo# Could not create INET socket: Address already in use IO::Socket::INET: Address already in use
cryo# tail exim_mainlog
2004-03-01 14:17:20 1AxmMK-000FCQ-HM == [email protected] routing defer (-51): retry time not reached
2004-03-01 14:17:20 1AwlXA-000A1L-NM == [email protected] routing defer (-51): retry time not reached
2004-03-01 14:17:20 1Axero-000EhL-0z == [email protected] routing defer (-51): retry time not reached
2004-03-01 14:17:20 1Awvex-000Amh-2z == [email protected] routing defer (-51): retry time not reached
2004-03-01 14:17:20 1AxI8V-000D6w-1g == [email protected] routing defer (-51): retry time not reached
2004-03-01 14:17:20 1AxUB1-000Dta-Ay Message is frozen
2004-03-01 14:17:20 1AxfWF-000Ejz-SZ Message is frozen
2004-03-01 14:17:20 1Axo9k-000FK5-LY Message is frozen
2004-03-01 14:17:20 End queue run: pid=58926
Try rebooting the system... ugly fix but it should do the trick.
Chris
OK still battling with this, restarted system, uncomment lines in exim.conf, started spamd which started properly this time
root 12150 0.0 5.8 15848 14972 p0 I 11:40AM 0:04.86 /usr/local/bin/perl /usr/local/bin/spamd
exim mainlog
2004-04-20 13:07:13 1BFu1x-0003Li-3P <= [email protected] H=(desk) [ip address] P=smtp S=1322 id=005301c426d0$80e8a5c0$ebf49fc2@switch
2004-04-20 13:07:13 SMTP connection from mail lost while reading message data (header)
2004-04-20 13:07:13 1BFu1x-0003Li-3P <[email protected]>: spamcheck transport output: An error was detected while processing a file of BSMTP input.
2004-04-20 13:07:13 1BFu1x-0003Li-3P ** [email protected] R=spamcheck_director T=spamcheck: Child process of spamcheck transport returned 2 from command: /usr/sbin/exim
2004-04-20 13:07:13 1BFu1x-0003Lp-BT <= <> R=1BFu1x-0003Li-3P U=mail P=local S=2616
2004-04-20 13:07:13 1BFu1x-0003Li-3P Completed
2004-04-20 13:07:13 1BFu1x-0003Lp-BT => brian <[email protected]> R=localuser T=local_delivery
2004-04-20 13:07:13 1BFu1x-0003Lp-BT Completed
Please help :(
Update...........
Foun this http://www.directadmin.com/forum/showthread.php?s=&threadid=2406&highlight=spamassassin and made the changes as per the last post in the topic.
Tried to send a mail internally and got..........
2004-04-20 16:19:32 SMTP connection from mail lost while reading message data (header)
2004-04-20 16:19:32 1BFx22-0003fh-K7 <[email protected]>: spamcheck transport output: An error was detected while processing a file of BSMTP input.
2004-04-20 16:19:32 1BFx22-0003fh-K7 == [email protected] R=spamcheck_director T=spamcheck defer (-24): Filter process failure
Also can't recieve mails from hotmail etc. I can send emails fine
Will this circle of madness never end :mad:
I remember getting that when the spamd (or spamc) programs were broken (can't remember exactly what it was) .. might have been the spamd not running, but it was quite some time ago.
Although this is an old topic, I have run into the same problem (for 2 users) after transferring all sites to a new server.
I found out that it had something to do with the administration of spamassassin in /home/<user>/.spamassassin. If there is a file called "bayes.lock" in this directory, you're in trouble.
The simple solution is to switch off spammassassin for this user in the controlpanel, delete all the files in /home/<user>/.spammassassin and switch spamassassin back on.
