plakjeworst
- Apr 28, 2016
I'm using the latest EXIM spamblocker configuration, which includes SRS support. However, SRS only works for a forwarded e-mail address if there is also a virtual mailbox for the same account.
I suspect this is because the forwarder redirect router in exim uses the 'unseen' option. This duplicates the recipient address so that if there is any mailbox for it, it will get delivered as well. The drop_solo_alias router will drop the copy if there was no mailbox for it after all. Some time ago I tried to add a header with headers_add in the forwarder router and these would also only work if there was both a forwarder and a mailbox, since unseen removes the headers for one of the copies, and it appears the wrong copy is removed by the drop_solo_alias router). It might be that something similar is the case for the srs router option.
