ssl does not work
ja3
At my server I visit https://domain.com/ and there is a screen to accept or not accept the ssl connection. But when I accept it there is just an 404 not found error and there should be a page. I tried it with different domains but there it also doesn't work?
Can somebody help me?
Thanks,
ja3
Presumably because you're using a shared cert that doesn't match the domain name, or because you're using a self-signed cert.
If either of the above are true, then so far, so good.
What page? Where did you upload a page? To what directory?[/quote]
the page for the ssl is in the domains/domain.com/private_html folder.... but it doesn't display the index
What index?
What's the name of the page in the private_html folder?
What are the permissions?
What is the ownername of the file?
I think it has something to do with a wrong domain in the certificate, if I create a certificate myself then the https works.
If the cert has a name mismatch, but you still accept it, it should still show the index.html file.
how can I create a new shared certificate on my server? Somethimes I see the index.html now and sometimes just the 404 error.
to create a shared certificate on your server, you'd create a certficate normally from the User Panel, but using an Admin account. When an Admin creates a certificate, it saves it as the shared server certificate.
