SSL installation problem with nginx
DaNgErOuS
hi
i have reverse proxy nginx with apache
i purchased the ssl and want install on my domain
i installed with this guid :
http://www.site-helper.com/ssl.html
i select Paste a pre-generated certificate and key and then put my certificate after private key
but when i check ssl with ssl checker website i see my ssl certificate dont be load and localhost certificate has been load
the ssl checker say my website protected with the server's certificate .
but i selected this part (Paste a pre-generated certificate and key) and save it .
how can i force my website use my purchased certificated instead of server certificate ?
the OS is Debian and enable SNI
the domain uses shared ip
thanks
