SSL Login Problems
mikenz
Auckland, New Zealand
I am currently locked out of my control panel due to some SSL problems.
I tried to get the panel running on SSL and had some problems, now when I try to login, it just takes me to the login page again.
I've tried to turn off DA SSL, via SSL=0, in directadmin.conf, but this does not help.
The DA error.log, shows:
<snip>
2005:10:02-14:23:52: ->error ssl
2005:10:02-14:28:49: Can't connect to ssl!
</snip>
P.S: This is not a firewall issue.
Please help, this is causing big problems not being able to login to the panel!
I have found posts on DA similar to this, mostly dated back years - but they havent helped solve this.
Regards,
-Mike
The best way to clear this up will be to contact DirectAdmin support.
Hey,
I'll ask...
Did you restart directadmin after making the change in the conf file?
David
