I have read all ssl posts and my head is spinning. Could someone please answer yes or no to the following questions, so I will know which general direction to go down? (Please note I am the admin of my server, running DA and CentOs 4.1). Please note that "mydomain.com" is not my domain but just example words for these questions)
1) Installing a ssl cert for a single domain (www.mydomain.com)
1a) Will all subdirectories (such as https://mydomain.com/page1.php) work also? (I assume anything in the DA private html would work)
1b) Will using squirrelmail from a link from my site work with the same ssl cert? (https://www.mydomain.com/squirrelmail)
2) Installing a ssl cert for DA panel ssl access.
2a) Can I have ssl DA access work for the above domain if I installed that same cert for DA?
2b) If yes, will the link to webmail(squirrelmail) work with the cert with no mismatch popup? Phpadmin also?
2c) Can I have all other resellers for other domains in DA *not* use ssl for DA panel access? (It appears DA is ssl for everyone or not).
2d) If no, do I have to install a different ssl cert into DA than the one discussed in 1a-b above for theirs (using other domain names for the urls into DA panel) to work?
3) If I have to install a server cert for DA to get everyone to pass the DA ssl access, is there any way to make all their links (from all their domains:2222 in DA panel) work to webmail/squirrelmail without getting the popup/mismatch?
My overall preference is to get all DA panel logins for the resellers and users to always pass the ssl without popups for both DA panel, links to PHPadmin, and webmail, OR,
Just have the same DA access work (DA panel and links to webmail)it work for the one domain only as described in 1a-1b, and force everyone else's panel items to always use just http:// (the one domain in 1a-b is mine obviously and my ssl access to DA panel is my biggest concern). But it can't make their links have the snakeoil or similar popup.
Thanks in advance for your time reading and your help.
