jjma
Installed tsep search from installatron and tried creating a new index but this is failing after 19 documents with the following error:
Couldn't add data: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near 's Hogmanay, millennium hogmanay, Hogmanay 2001, Scottish new, y
I suspected that the problem was the quotes in "near's" so turned magic_quotes off in the root directory but I still have the same problem.
Php version 4.3.10
Mysql 4.0.23
Any help is appreciated.
regards
Jon
Php version 4.3.10
Mysql 4.0.23
regards
Jon
