Kilian
I've got DA setup to use SSL (SSL=1).
I've also used my Thawte Certificate for that.
I can login to DA on https://secure.vermaelen.be:2222
And also https://secure.vermaelen.be is using the same Cert.
Works fine.
However. If I link from a page on port 2222 to another page on my normale secure site, things go wrong.
If I click WEBMAIL on my DA panel, my browser goes to https://secure.vermaelen.be/squirrelmail and I get the error PAGE NOT FOUND.
If I open a new browser and go to the same url it works fine.
Even stranger. If I hit refresh from the error page, it works fine !!
I made a custom login page: https://secure.vermaelen.be/nl/login.html
Works fine. But if I log out or I enter a wrong password trying to login, things go wrong. Again PAGE NOT FOUND
In the custom login page I link to https://secure.vermaelen.be/nl/loginerror.html if there's an error and to https://secure.vermaelen.be/nl/logout.html as logout page.
Hitting refresh won't work now, instead I get the defauld error page or default logout page from DA. If I open a new browser and enter those url's manually. They work fine.
I'm puzzled.
Any idees ??
Works fine.
I'm puzzled.
Any idees ??
