subdomain problem
kfyonur
i can't install anything on my subdomain.
i install to https://ilan.audiclubtr.com but i didn't install to http://ilan.audiclubtr.com
PHP:
! PHP for the selected domain has failed.
Installatron Plugin is unable to install to a domain where PHP is not working.
Your hosting provider can help you resolve this error.
Error code: 1; HTTP code: 500
Is php enabled in directadmin for the user? You will have to go to modify user in list users and make sure the php box is checked.
Create a php file with just the following code and then surf to the file to see if php works.
<?php phpinfo(); ?>
<?php phpinfo(); ?>
how can i do that ?
how can i do that ?
You can only do that if you're the server administrator or if you're a reseller. If you're a client of a hosting company only they can enable it for you.
