I want to install subversion.
I did everything the INSTALL docs told me but i get this error:
'undefined symbol: dav_xml_get_cdata'
When i search on google, almost everytime the answer is to configure apache with --enable-dav and --enable-dav-fs
Well i did that but it doesn't seems to work. I use the DirectAdmin customapache script.
It ran this 3 times. Installed subversion again etc. Every time I get the same error.
There should be a mod_svn.so file but I can't find that one anywhere on my filesystem.
I have apache2, so I run .build apache_2. The configure statement above is in the configure.apache_2 file.
So everything should be working, but it seems dav doesn't get installed.
What can i do??
./configure \
--enable-ssl \
--prefix=/etc/httpd \
--exec-prefix=/etc/httpd \
--bindir=/usr/bin \
--sbindir=/usr/sbin \
--sysconfdir=/etc/httpd/conf \
--enable-module=all \
--enable-rewrite \
--enable-suexec \
--with-suexec-docroot=/ \
--with-suexec-caller=apache \
--with-suexec-userdir=public_html \
--with-suexec-logfile=/var/log/httpd/suexec_log \
--with-suexec-bin=/usr/sbin/suexec \
--includedir=/usr/include/apache \
--libexecdir=/usr/lib/apache \
--datadir=/var/www \
--localstatedir=/var \
--disable-auth-dbm --disable-auth-db \
--enable-dav=shared \
--enable-dav-fs=share
What can i do??
