Subversion dav problem
chielsen
I want to install subversion.
I did everything the INSTALL docs told me but i get this error:
'undefined symbol: dav_xml_get_cdata'
When i search on google, almost everytime the answer is to configure apache with --enable-dav and --enable-dav-fs
Well i did that but it doesn't seems to work. I use the DirectAdmin customapache script.
./configure \
        --enable-ssl \
        --prefix=/etc/httpd \
        --exec-prefix=/etc/httpd \
        --bindir=/usr/bin \
        --sbindir=/usr/sbin \
        --sysconfdir=/etc/httpd/conf \
        --enable-module=all \
        --enable-rewrite \
        --enable-suexec \
        --with-suexec-docroot=/ \
        --with-suexec-caller=apache \
        --with-suexec-userdir=public_html \
        --with-suexec-logfile=/var/log/httpd/suexec_log \
        --with-suexec-bin=/usr/sbin/suexec \
        --includedir=/usr/include/apache \
        --libexecdir=/usr/lib/apache \
        --datadir=/var/www \
        --localstatedir=/var \
        --disable-auth-dbm --disable-auth-db \
        --enable-dav=shared \
        --enable-dav-fs=share
It ran this 3 times. Installed subversion again etc. Every time I get the same error.
There should be a mod_svn.so file but I can't find that one anywhere on my filesystem.
I have apache2, so I run .build apache_2. The configure statement above is in the configure.apache_2 file.
So everything should be working, but it seems dav doesn't get installed.
What can i do??
