soulshepard
- Feb 7, 2008
dear all,
i installed suhosin the patch on my server (together with mod_ruid2), i have php 5.2.17 and patched the suhosin patch 5.2.16 according to the search and replace method as named on the forum:
my version:
now when i look at the php -v info i see its compiled
and i have a custom template
but when i tried to test a disabled function it seems all functions were enabled!
like i add curl_init or curl_exec
further i do not see with phpinfo()
and blacklist named!!!
does anyone had or has this?
this is the first time i try to get suhosin the patch to work. as it seems it might be the best choice for using suhosin vs the module. purhaps i am better off checking the module or as i read people also use both?!
my version:
rm -rf php*
./build set clean no
tar xzf php-5.2.17.tar.gz
wget http://download.suhosin.org/suhosin-patch-5.2.16-0.9.7.patch.gz
gunzip suhosin-patch-5.2.16-0.9.7.patch.gz
mv suhosin-patch-5.2.16-0.9.7.patch suhosin-patch-5.2.17-0.9.7.patch
sed -i 's/5.2.16/5.2.17/g' suhosin-patch-5.2.17-0.9.7.patch
patch -p0 < suhosin-patch-5.2.17-0.9.7.patch
vi build #check for every FILE=${CWD}/php-${PHP5_VER} line and at 3 line down comment this corresponding line
zie: http://www.directadmin.com/forum/archive/index.php/t-35646.html
./build php n
./build set clean yes
PHP 5.2.17 with Suhosin-Patch 0.9.7 (cli) (built: Feb 20 2012 09:41:28)
Copyright (c) 1997-2009 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2010 Zend Technologies
with the ionCube PHP Loader v4.0.5, Copyright (c) 2002-2011, by ionCube Ltd.
|?DOCROOT=`HOME`/domains/`DOMAIN`/public_html|
|?OPEN_BASEDIR_PATH=`HOME`/:/tmp:/var/tmp:/usr/local/lib/php/|
<VirtualHost |IP|:80 |MULTI_IP|>
|?CGI=ScriptAlias /cgi-bin/ `DOCROOT`/cgi-bin/|
ServerName www.|DOMAIN|
ServerAlias www.|DOMAIN| |DOMAIN| |SERVER_ALIASES|
ServerAdmin |ADMIN|
DocumentRoot |DOCROOT|
|CGI|
|USECANONICALNAME|
#SuexecUserGroup |USER| |GROUP|
RMode config
RUidGid |USER| |GROUP|
RGroups apache
|CUSTOM|
#RDocumentChRoot /home/|USER| |DOCROOT|
CustomLog /var/log/httpd/domains/|DOMAIN|.bytes bytes
CustomLog /var/log/httpd/domains/|DOMAIN|.log combined
ErrorLog /var/log/httpd/domains/|DOMAIN|.error.log
<Directory |DOCROOT|>
Options +Includes -Indexes
php_admin_value upload_tmp_dir "/home/|USER|/tmp"
php_admin_value suhosin.executor.func.blacklist "system, shell_exec, exec, passthru, php_uname, popen, posix_kill, posix_mkfifo, posix_setpgid, posix_setsid, posix_setuid,posix_setgid, posix_uname, proc_close, proc_nice, proc_open, proc_terminate"
php_admin_value session.save_path "/home/|USER|/tmp"
php_admin_value soap.wsdl_cache_dir "/home/|USER|/tmp"
php_admin_value eaccelerator.cache_dir "/home/|USER|/tmp/eaccelerator"
|*if CLI="1"|
php_admin_flag engine |PHP|
<IfModule !mod_php6.c>
php_admin_flag safe_mode |SAFE_MODE|
</IfModule>
php_admin_value sendmail_path '/usr/sbin/sendmail -t -i -f |USER|@|DOMAIN|'
|*endif|
|*if OPEN_BASEDIR="ON"|
php_admin_value open_basedir |OPEN_BASEDIR_PATH|
|*endif|
|*if SUPHP="1"|
suPHP_Engine |PHP|
suPHP_UserGroup |USER| |GROUP|
|*endif|
</Directory>
<Location /phpMyAdmin>
RMode config
RUidGid webapps webapps
RGroups apache
</Location>
<Location /phpmyadmin>
RMode config
RGroups apache
</Location>
<Location /squirrelmail>
RMode config
RGroups apache
</Location>
<Location /roundcube>
RMode config
RGroups apache
</Location>
<Location /uebimiau>
RMode config
RGroups apache
</Location>
<Location /webmail>
RMode config
RGroups apache
</Location>
<Location /atmail>
RMode config
RGroups apache
</Location>
|HANDLERS|
|MIMETYPES|
</VirtualHost>
