Symlink problem with /var/spool
l0rdphi1
Due to space issues with my /var partition, I have /var/mail and /var/spool symlinked to /home/spool/mail and /home/spool, respectively. This creates problems when I go to remove a domain. I get-
Domain Deletion Results
Details
Error deleting domaddin.cc
Unable to remove /var/spool/virtual/domaddin.cc as it contains a symbolic link
Unable to open domain pointers file
domaddin.cc's config files have been removed
Click HERE to return
Any ideas?
I remember adding that check a few releases ago. It was done globally for the function to remove a directory and it's files. I've just changed the code for you to ignore any symlinks when removing the /var/spool/virtual/domain.com directory. (next release)
I am having the same problem almost 3 years later. I have /var symlinked to /home/var which is another partition. Whenever I delete a domain is gives the error:
Error deleting tmpdomain.com
Email:destroy: Unable to remove /var/spool/virtual/tmpdomain.com as it contains a symbolic link
tmpdomain.com's config files have been removed
Are you sure have a recent version of DA installed? What version are you running?
Hi Jeff,
I am running version 1.28.1.
I see 1.29 is out now but I doubt that will make a difference unless the issue has specifically been addressed.
Found the code, added the flag to ignore the symlink. Available for next relelase.
If you need this fix now, send us an email including your OS and version.
