System info and logs
Dennis
The Netherlands
I do not know if this is posted on the form already....but:
- Can you add the PHP version in the 'System Information' screen on Admin Level? Since this is installed with DA.
- Can you add the default mysql errorlog in the 'Log Viewer'? Maybe that is not working because of the custom logdir and place. But on my system there is only one '.err' file.
Just some suggestions :)
Regards,
Dennis
The files visible through both Log Viewer and the File Editor can be edited. The configuration files for those can be found in /usr/local/directadmin/data/templates I believe.
