System load average
dannygoh
Malaysia
i just run the top command
what is "load average: 0.13, 0.29, 0.49"
i'm running a P4 3GHz HT with 1GB RAM. until how high is the load average then i should afraid?
Google is wonderful:
From the Linux kernel mailing list:
On Wed, 9 Dec 1998 10:23:14 +0000 (WET),
Antonio M. Trindade (trindade at student.dei.uc.pt) wrote:
The load average is the average number of runnable processes in periods
of 5 sec., 5 min and 15 min. The calculating code is in kernel/sched.c and
include/linux/sched.h. The real calculation is done with a macro. If you
are interested in changing the calculating parameters, you might want to
take a look at include/linux/sched.h
yep mr. jeff is correct. You shouldn't worry and it should go up decently high when doing backups and processor usage things.
A friend of mine had a spammer on his box and load was 16.
