Hello
I have a problem. I installed cloudlinux. And I activated it.
I did everything right.
When I define a user. And then I go to the user panel. The settings I create on the php selector section. None of them work. The settings are saved
But the changes are not applied to the user.
For example, if I set the value of max_input_time to any number, it will not be applied.
But when I go to the PHP Settings section and there I create a max_input_time and define a value for it. Applies to the server.
