themes problem
papatango
been trying for ages now, but DirectAdmin WILL NOT LET ME UPLOAD THEMES - it simply says that i should only pick one theme at a time, precisely what I am doing!
Any ideas?
Make sure you click "Upload" (bottom right) after you select the file and set the skin name. Don't click any of the buttons above where you enter the filename, as that is where you apply it to yourself *after* you've uploaded it.
That is exactly what I have been doing! I've been doing it exactly as your guide tells us to and still receive the error!
The only way that the mentioned error message could appear if you've clicked "Upload" is if the form value:
action=upload
is not included in the POST.
If you're using a custom skin, make sure that the following is found in the form:
<input type="hidden" name="action" value="upload">
What browser are you using?
Have you tested uploading files in the Filemanager?
