too much fail logins on "Brute Force Monitor"
Yasham
hello,
I notice in "Brute Force Monitor" there is to much failures logins and it's source is my server IP? how I can solve it without blocking my server ip :D
please check the image in attachments ..
If you use nginx+apache, then you need to re-install apache and the IPs detection should work fine.
thanks for your replay, yes I am using "nginx+apache", but can you give me more details please , how I can re install apache and why this problem happen
best regards
