I am making the assumption that Uebimiau is now a "dead" project? half the links do not appear to work on the website and it is not compatible with PHP5.5.
Would I be right in making this call to remove it from my server?
The reason I started thinking about this was due to the following;
ERROR (8192): preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead (/var/www/html/webmail/smarty/Smarty_Compiler.class.php:92)ERROR (8192): preg_replace(): The /e modifier is deprecated, use preg_replace_callback instead (/var/www/html/webmail/smarty/Smarty_Compiler.class.php:92)
Thanks.
Thanks.
