Unknown storage engine 'InnoDB'
chatsaz
hi
my server error
How I solved???
Please post the output of:
cat /etc/my.cnf
[mysqld]
 innodb_use_native_aio = 0
 innodb_file_per_table=1
 innodb_log_file_size = 12M
 default-storage-engine = myisam
 key_buffer = 8M
 query_cache_size = 8M
 query_cache_limit = 4M
 max_connections=25
 thread_cache=1
 skip-innodb
 query_cache_min_res_unit=0
 tmp_table_size = 4M
 max_heap_table_size = 4M
 table_cache=256
 concurrent_insert=2
bind-address=46.105.248.90
You have skip-innodb in /etc/my.cnf
remove that line and try again.
im remove
 key_buffer = 8M
 max_connections=25
 thread_cache=1
 tmp_table_size = 4M
 table_cache=256
 concurrent_insert=2
but Yet the problem remains
Your InnoDB tables are most likely corrupted and that's why InnoDB fails to register as a storage engine:
150707  2:56:58 [ERROR] Plugin 'InnoDB' init function returned error.
150707  2:56:58 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
The simplest way will be to rebuild MySQL tables from a backup.
I do not have a backup
There is no possible way to be solved????
