unzip problem
endorama
Hi, I have always uploaded files by directadmin web panel and then extracted them without a problem. Few weeks ago switched to almalinux (not sure if its connected) and now when I try to extract a zip or tar.gz DA ask me to choose the files to extract which is impossible bcs there are 64 pages of files. Is there an option to set or some fix to extract whole file?
When you say switched? from Debian..
Sorry I thought you couldn't unzip at first..
Did you see if zip was installed?
is zip=1 set in directadmin.conf
Well it worked with evolution theme. I am a fan of enhanced tho so would like to have it fixed :)
I see, when I click on it I see that what is on screen I've sent in first post
You mean after you click extract? If so that is all the extracted files from the zip is it not?
Try with a smaller zip with files you added to it like a test.zip with 2 files like test.txt and test2.txt
Yes. I click extract and get this listing of files to check. I can unzip files from first page :-) no point of upload small file
