Urgent need - Issue while connecting my domain to webflow
saleembabu
i have completed an website in Webflow. the client has a domain hosting from direct admin and we need to connect the domain to webflow.i have tried all tutorials still can't find a solution. client has urgent requirement. any one has a solution please help.
t for the website. if any one has a solution please let me know.
There are 1 thing as far as I can see.
First the SPF value is not propegated yet as webflow clearly sends an error that it's unable to verify the domain. And we can't check either since you masked it.
Also, are you running your own nameservers? If yes then it's fine. If not, you need to copy those DNS records to the DNS you're using.
Otherwise seems you might just need to wait a while.
If that is not working, I would suggest your customer contacts webflow support as they do have a support part.
