mediumfriedchips
- Oct 23, 2020
So I have been experimenting to see if I can extend direct admin storage by using S3 storage and the answer is yes.
So I managed to mount idrive S3 storage using s3fs and it worked
Then i decided to go further and see if i could actually use it as a home directory for DA and move the user files there but i was stuck with the problem with changing the permissions as s3fs might not (I'm not sure) fully support Unix-like permissions because S3 is an object storage service rather than a file system with native support for POSIX permissions.
So here is what i am, trying to do , this whole point is just for authentication and monitoring i have a bunch of servers and some of them can not back up directly to S3 storage as direct admin is still working on a solution.
So i was hoping that with this , i can mount the storage on a DA backup server , create users and then use those users to send data from another DA server to back up but using FTP from that DA server then the backup server does the whole FTP to S3 since data sent to it will be automatically saved to S3 . And also DA has data monitoring so i could be able to measure bandwidth and data storage quotas from that server.
Anyone with an idea on how i can win this ?
Or am i approaching this the wrong way ?
