Using wildcard ssl with directadmin
psycho
Hey,
I just bought Wildcard ssl using godaddy, I know how to install a normal certifcate
but how can I install the wildcard ssl and allow all the subdomains in directadmin that related to use this cert?
Thanks in advance
Guy.
None of this is tested; it just seems reasonable to me:
If all the subdomains are created using the subdomain feature I'd think that it would work automatically if the Cert was installed for the main domain.
If all the subdomains are created as separate domains, then they all need to have the Certificate installed.
If this doesn't work let me know and I'll try to find out.
Wildcard SSL on Directadmin
Setting up wildcard SSL with DA is the same as setting up a standard SSL cert with one exception.
Instead of www. in the common name, you need to use *:
Common name: *.YourDomainName.com
Hope this helps someone. I broke my whole website for an hour trying to get this to work!
