Was Directadmin Control Panel Heartbleed affected?
dihuta
Hi!
I check my Directadmin control panel with ilippo.io/Heartbleed/, it said my site is unaffected, but possible.lv/tools/hb/ said it was unaffected, and should be upgraded asps.
Does anybody confirm was Directadmin CP affected or not?
Thank you!
Is not DA that can or cannot be affected, is OpenSSL.
If you did upgrade your OpenSSL you need to reboot the server (or at least manually restart each service that may use SSL as HTTPD, DirectAdmin,Exim,Dovecot,PureFTPd,ProFTPd).
Also, you did write that BOTH check says you are unaffected, so actually you wrote that you're fine...
Regards
