We have a problem with httpd
Niels90
Dear Sir / Madam,
AH00526: Syntax error on line 43 of /usr/local/directadmin/data/users/admin/httpd.conf:
<VirtualHost> cannot occur within <VirtualHost> section
A ./build rewrite_confs from admin/httpd.conf does not yet receive the error
Apache 2.4.20
DirectAdmin 1.50.0
Exim 4.87
MySQL 5.5.31
Named 9.8.2rc1
dovecot 2.2.23 (806d709)
pure-ftpd 1.0.42
Php 5.5.34
you know a solution?
I hope to have informed you sufficiently.
Sincerely,
Niels90
Since line 43 is giving the error, what does line 43 say?
It normally should point to a Customlog statement.
Did you make any manual changes on virtualhost or made an entry or addition via the DA control panel?
Post what your line 43 of /usr/local/directadmin/data/users/admin/httpd.conf, posting the error you are getting again doesn't help. Perhaps even better, post your /usr/local/directadmin/data/users/admin/httpd.conf file and we should be able to see the problem.
It seems you have inserted a custom code for a domain in Directadmin. Go to admin level and check it.
I don't see any reason on why you have <VirtualHost> within <VirtualHost> section.
<VirtualHost ****:80 >
ServerName www.powerweb4you.nl
ServerAlias www.powerweb4you.nl powerweb4you.nl
ServerAdmin [email protected]
DocumentRoot /home/admin/domains/powerweb4you.nl/public_html
ScriptAlias /cgi-bin/ /home/admin/domains/powerweb4you.nl/public_html/cgi-bin/
UseCanonicalName OFF
<IfModule !mod_ruid2.c>
SuexecUserGroup admin admin
</IfModule>
<IfModule mod_ruid2.c>
RMode config
RUidGid admin admin
#RGroups apache access
RGroups @none
</IfModule>
CustomLog /var/log/httpd/domains/powerweb4you.nl.bytes bytes
CustomLog /var/log/httpd/domains/powerweb4you.nl.log combined
ErrorLog /var/log/httpd/domains/powerweb4you.nl.error.log
<Directory /home/admin/domains/powerweb4you.nl/public_html>
php_admin_flag engine ON
php_admin_value sendmail_path '/usr/sbin/sendmail -t -i -f [email protected]'
php_admin_value mail.log /home/admin/.php/php-mail.log
php_admin_value open_basedir /home/admin/:/tmp:/var/tmp:/usr/local/lib/php/:/usr/local/php55/lib/php/
</Directory>
</VirtualHost>
<VirtualHost ****:443 >
SSLEngine on
SSLCertificateFile /etc/httpd/conf/ssl.crt/server.crt
SSLCertificateKeyFile /etc/httpd/conf/ssl.key/server.key
SSLCACertificateFile /etc/httpd/conf/ssl.crt/server.ca
DocumentRoot /home/admin/domains/powerweb4you.nl/private_html
</IfModule>
RMode config
RUidGid admin admin
RGroups @none
</IfModule>
<Directory /home/admin/domains/powerweb4you.nl/private_html>
</Directory>
</VirtualHost>
stand twice, in httpd.conf
it should only be DirectAdmin version 1.50.0
but there is DirectAdmin version 1.50.0 and DirectAdmin version 1.48.3 httpd.conf
# Auto generated apache config file by DirectAdmin version 1.50.0
# Modifying this file is not recommended as any changes you make will be
# overwritten when the user makes any changes to their website
# For global config changes that affect all Users, see this guide:
# http://help.directadmin.com/item.php?id=2
# For local config changes that only affect one User, see this guide:
# http://help.directadmin.com/item.php?id=3
<Directory "/home/admin/public_html">
RMode config
RUidGid admin admin
RGroups @none
</IfModule>
<IfModule mod_fcgid.c>
</IfModule>
</Directory>
# Auto generated apache config file by DirectAdmin version 1.48.3
# overwritten when the user makes any changes to his/her website
RMode config
RUidGid admin admin
RGroups @none
</IfModule>
</IfModule>
</Directory>
Your line 43 of the httpd.conf you posted doesn't even have a VirtualHost tag, did you include the whole httpd.conf including comments? If so, post the real file, since we can all do an nslookup of your serveralias/servername, hiding your IP address does nothing.
