Hi all,
I have this issue for so long without resolution, DA support were helpful but still with same result.
The issue is i cant get the full logging (traffic) of the domains i have, now i have checked (/var/log/httpd/domains/domain.com.log) and there is data also i have checked CROND is running (ps -ax |grep cron) with success.
Also i checked the Webalizer is running (ps -ax |grep cron) with successfull result
[root@server]# webalizer
Webalizer V2.01-10 (Linux 2.4.21-9.0.1.EL) English
Using logfile STDIN (clf)
Creating output in current directory
Hostname for reports is 'es.jbmc-software.com'
History file not found...
ONE Major thing i noticed wich is the HOSTNAME from above result was different than the domain name i want to log . for example the domain i want to view the log for is (abc.com) and from the command above i got (different host name xyz.com)
if it is the cause how to resolve it ?? if not do you have any suggestions?
Note that once i click on the domain to view the webalizer stats i got static results (like 6 visitors / month and never changed)
Appreciate your answers.
Thanks in advance.
Thanks in advance.
