Weird Problem with apache2
Dr-Host
Israel
everytime theres a change regarding the apache it crashs with the following error
[notice] caught SIGTERM, shutting down
when I create a new user. changing users IPs and so on
and one time I got socket allready in use
does anyone else got that and if so any solutions?
Thanks,
David
Dr-Host.co.il
anyone?
John, Mark?
for now I've solved it by setting a cronjob that
killall -s9 httpd
service httpd start
every 45min
but its not a prement solution espicaily if a user has just made a change ( created subdomain etc. )
the hole server will be down for 45min +/- or until the datacenter will notify me that the HTTPD is down
When you did the conversion to Apache 2 did you change the Directadmin Configuration to reflect your move to apache 2?\
You can let DA know to use the apache 2 files by setting "apache_ver=2.0" in your directadmin.conf file, but the convertor will do that for you anyway.
Sometimes the convertor doesn't change it so you have to do it yourself.
