wget not working in cron; jailshell problem?
flexjoly
Apeldoorn, Netherlands
I am trying to do a wget from an external url. Logged in as root, it works fine (manually). But as a cron the connection is refused. Chatgpt tells me it may have to do with different shell and even because of jailshell.
So I changed the shell to /bin/bash
Jailshell is installed with custombuild. But I cannot find how to remove it there.
I changed directadmin.conf to "jail=0".
In the user settings: jailed is not checked.
But the cron still does not work.
user crontab:
000=52 * * * * /usr/bin/wget --inet4-only -O /home/client/domains/xxxx.com/files/front/prodvar_$(date +\%Y\%
m\%d_\%H\%M\%S).json "https://ftbserv.xxxx.cloudapp.azure.com:3000/xxxx"  >> /home/client/domains/xxxx.com/files/download_front.log 2>&1
001=52 * * * * env > /home/client/domains/xxxx.com/files/cron_env.log
MAILTO=
PATH=/usr/local/php82/bin:/home/client/.local/bin:/home/client/bin:/usr/share/Modules/bin:/usr/local/bin:/usr/bin:/usr/l
ocal/sbin:/usr/sbin
SHELL=/bin/bash
What am I doing wrong? And how to remove jailshell?
Thanks in advance!
Login as the user or su to the user and try the wget command. If there is an error of some kind then it will tell you.
