hackerpitbull
- Dec 25, 2004
DA dosn't support it yet?
Are you using mysql 64bit? apache 64bit?ballyn said:I've been running the current version on 64-bit Centos 4 for a couple of months now without any problems. The apache build is the most troublesome--there's a thread somewhere about some tweaks.
I believe that there's also a thread somewhere saying that this will be fully supported in the near future.
Ok thxballyn said:Yeah, using Centos MySQL 4.1 64-bit and apache from customapache (which will compile 64-bit unless you try really hard not to).
Problems are mostly with compiling, but I noticed that the customapache build script does recognize 64-bit operating systems now and makes some changes.
The performance improvement is minimal for the most part. Some operations (like gzip) are noticeably faster, but overall the performance difference is very difficult to detect.
