Wildcard SSL CSR generation failure. Please help.
wheatgrass
To generate a wildcard SSL CSR, I have to enter the following in the Common Name field:
*.domainname.com
However, when I tried that in DA, I got an error message saying that it's invalid. Please help.
I'll update the formchecking to allow * characters for the common name so you can use *.domain.com.
Available for the next release.
For the time being, you can do it manually:
/usr/bin/openssl genrsa 1024 > private.key
/usr/bin/openssl req -new -key private.key
May I know when will be the next release? If I have to do it manually as per your code, do I log in as admin or user? After login, do I go into the admin's or user's /usr/bin/openssl?
The release won't be for a while.
For manually via ssh, it doesn't really matter.
You can be under any user, in any directory (that the logged in user has write access in). The only thing that matters is the key can csrt created. Save their output and they'll be used when you get the actual certificate back with from your csr (you *need* the key to use the new cert, don't lose it)
