XMLRPC problems with Wordpress
kristian
Norway
A customer of ours have contacted us regarding a problem with xmlrpc. It's best described here, so I won't go into details in this post:
http://www.johncow.com/html-tags-getting-stripped-out-of-wordpress-via-xmlrpc/
Their suggested fix is "A) This is ultimately resolved with the release of PHP 5.2.9 and libxml2 2.7.3. –> So see if your host will do that for you".
I'm currently running PHP 5.2.11 though, and phpinfo() says "libxml2 Version 2.7.2". The OS is CentOS 5.4, and it says:
# rpm -qa | grep libxml2
libxml2-2.6.26-2.1.2.8
Firstly, I'm not sure why phpinfo() reports a newer version of libxml2 than what I have installed.
Secondly, I'm not sure how I should go about fixing the problem, as the CentOS package is the latest available version, and PHP is well above the fixed version.
Any suggestions? All help appreciated!
Ah yes, didn't notice that custombuild actually builds libxml2 itself. Should be able to sort it out then. Thanks for the feedback. :)
