Hello !
Since this morning I have a problem with my server using RHEL 8.5 :
Do you have any advice to fix that?
Thanks for help !
yum update
Failed to set locale, defaulting to C.UTF-8
Updating Subscription Management repositories.
Last metadata expiration check: 0:58:53 ago on Sun Jul 7 14:46:52 2024.
Error:
Problem: package libnghttp2-devel-1.33.0-5.el8_9.x86_64 from @System requires libnghttp2(x86-64) = 1.33.0-5.el8_9, but none of the providers can be installed
- cannot install both libnghttp2-1.33.0-6.el8_10.1.x86_64 from rhel-8-for-x86_64-baseos-rpms and libnghttp2-1.33.0-5.el8_9.x86_64 from @System
- cannot install both libnghttp2-1.33.0-6.el8_10.1.x86_64 from rhel-8-for-x86_64-baseos-rpms and libnghttp2-1.33.0-5.el8_9.x86_64 from rhel-8-for-x86_64-baseos-rpms
- cannot install the best update candidate for package libnghttp2-1.33.0-5.el8_9.x86_64
- problem with installed package libnghttp2-devel-1.33.0-5.el8_9.x86_64
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
/usr/local/directadmin/directadmin version
DirectAdmin v.1.664 e660b56ef8fc2a8ff370c15d2f0b70dfe9d4697d
cat /proc/version
Linux version 4.18.0-553.5.1.el8_10.x86_64 ([email protected]) (gcc version 8.5.0 20210514 (Red Hat 8.5.0-22) (GCC)) #1 SMP Tue May 21 03:13:04 EDT 2024
Thanks for help !
