Ugrade Perl to 3.8.8
DRKT
Hi!
how upgrade perl 3.8.0 to 3.8.8 ? and how install CPAN?
That would be a downgrade. The current version is 5.8.8. Perl and cpan are automatically installed in most distributions.
Sorry my Perl version is 5.8.0 and i want upgrade to 5.8.8 how?
Based on the SpamAssassin 3.2.0 thread, the new SA requires features that indirectly require Perl 5.8.8.
I think you mean:
wget http://www.perl.com/CPAN/src/stable.tar.gz
Will this modify or harm the current Perl paths in CentOS 3.8? Rather what I'm asking is that, does CentOS 3.8 have custom path's for perl that if I was to compile perl from source that it'd put it in a different location??
It might have been installed at /usr/local/bin/perl, but /usr/bin/perl (the old one) has higher priority in the $PATH....
Type:
updatedb
locatel perl |grep bin
to see what you have.
Check the versions of those files directly, eg:
/usr/local/bin/perl -v
don't work...
if write: perl -v
i have always perl 5.8.0
if write: /usr/local/bin/perl -v ...it's ok
why?
Because now you have two versions of perl installed. One in /usr/bin/perl and one in /usr/local/bin/perl
If you do not want to delete the old installation then change the top line of your perl scripts to #!/usr/local/bin/perl
if i want 5.8.8 by default? and spamassassin have same error...
thanks!
