m4ri00sh
- May 20, 2007
OK, I had some problems with installing APF so I researched:
I found the informations at:
http://www.techyblog.com/content/view/49/27/
and here
http://www.scriptinstallation.in/apf_ipt_state.html
OK here you go (in case the websites crashed):
.. cd /opt
1. wget http://www.r-fx.ca/downloads/apf-current.tar.gz
2. wget http://www.mnxsolutions.com/scripts/apf.debian.init
3. tar -xzvf apf-current.tar.gz
4. cd apf-0.9.6-1/
5. ./install.sh
You will recieve back messages like below.. Notice the cp error.
Installing APF 0.9.6-1: cp: cannot create regular file `/etc/rc.d/init.d/apf': No such file or directory
Completed.
Installation Details:
Install path: /etc/apf/
Config path: /etc/apf/conf.apf
Executable path: /usr/local/sbin/apf
AntiDos install path: /etc/apf/ad/
AntiDos config path: /etc/apf/ad/conf.antidos
DShield Client Parser: /etc/apf/extras/dshield/
Other Details:
Listening TCP ports: 21,25,53,465,587
Listening UDP ports: 53,1812,1813,48921
Note: These ports are not auto-configured; they are simply presented for information purposes. You must manually configure all port options.
6. mv /opt/apf.debian.init /etc/init.d/apf
7. chmod +x /etc/init.d/apf
8. update-rc.d apf defaults
9. Edit /etc/apf/conf.apf to appropriate settings you may include Listening TCP/UDP from above if approp.
10. /etc/init.d/apf start
11. Validate, change /etc/apf/conf.apf DEVEL_MODE="0"
12. restart apf; /etc/init.d/apf restart
but I got another error .....
Unable to load iptables module (ipt_multiport 1) so ..... I see you might have problem as well with ipt_state..... you need to...
I have recently upgraded kernel of my linux server to 2.6.17.6. After this, APF Firewall stoped working. It give error message on starting firewall.
[root@server10 apf]# apf -s
Unable to load iptables module (ipt_state), aborting.
The problem is due to module ipt_state is no longer exists, the name is changed to xt_state.
On my server, the module is available at "/lib/modules/2.6.17.6/kernel/net/netfilter"
The error can be fixed by editing /etc/apf/internals/functions.apf
# vi /etc/apf/internals/functions.apf
FIND
ml ipt_state 1
ml ipt_multiport 1
REPLACE WITH
ml xt_state
ml xt_multiport
OK, Restarted apf and it seems to work, no errors, etc....
If someone sees a problem in that solution please respond....
I forgot about this: (found in different thread of this forum) oops
Scroll down to the "Common ingress (inbound) TCP ports section. At this point you need to find the correct configuration for your control panel.
-----DIrect Admin-----
IG_TCP_CPORTS="21,22,25,53,80,110,111,143,443,587,953,2222,3306,32769"
IG_UDP_CPORTS="53,111,631,724,5353,32768,32809"
and here
.. cd /opt
4. cd apf-0.9.6-1/
5. ./install.sh
Completed.
Other Details:
FIND
ml ipt_state 1
ml ipt_multiport 1
REPLACE WITH
ml xt_state
ml xt_multiport
