Etch / sshd (received signal 15)
Zoner
auth.log:Jul 4 23:04:41 wwwtest sshd[2227]: Received signal 15; terminating.
Any hint what can cause this ?
so working while for ok, then coming terminating signal, and then sshd wont work anymore, and cant login anymore in ...
not found anything on logs ...
I remove apt-get remove openssh-server, and then installed again apt-get install openssh-server
still not working, not any clue what caused that problem ...
Now tested different kernel versions, but same problem.
Machine is HP Proliant DL 320 G5 / 4G ram + 3ware 8006-2lp raid controller. This is "last" hp machine what we buy, others are Fujitsu Siemens and Dell, whitout problems. Also tested same configuration VPS, but there not any problem.
### More info 14.7.2007 ###
We contacted Hp Hardware support, and now they have changed almoust everything on that machine: Motherboard, memorys, cpu, and still doing that same. Also notified, when we using custom build, and when it compling php, it always crash sshd daemon.
now we not trying use anymore that machine with DA, just make others jobs with that ... and OS was Debian Etch 4.0
