Reseller/user httpd.conf not included in the main httpd.conf after creation
Imtek
The Netherlands
When i create a user it creates everything perfectly but the next line doesnt get added to the main httpd.conf when i create a user:
Include /usr/local/directadmin/data/users/username/httpd.conf
When i add it manualy it works ofcouse, but thats not a solution.
Can anybody help me figure out this problem :confused:
Maybe it's in /etc/httpd/conf/extra/directadmin-vhosts.conf :)
If you have everything on it, just add this line to httpd.conf:
Include /etc/httpd/conf/extra/directadmin-vhosts.conf
Since when has that changed, i dont have include on that file in my main httpd.conf :confused:
That should have only changed if you have installed smtalk's new custombuild system. I do not think that the new system is shipped with new installs of DA yet. So, if you are still using the customapache build system, this might not be your problem.
